Results 1 to 6 of 6
Thread: convert blocks into data points
    2011-12
    5
    Default convert blocks into data points
    Does anybody know how to convert blocks into data points in Land Development Desktop 2i?
    Here is what I want to do.
    I have the layout of a drainage system. It contains 1200+ blocks that represent catch basins. Catch basins are the openings that collect the water to send it to the pipes.
    I need the position of each block to recreate a model of the drainage layout system. The problem is that I have no data (x,y, the z value at this point can be set = 0) attach to those blocks.
    I am able to label the blocks by point, this way each blocks is labeled with its coordinates (at the center point) but I need to access the data so I can manipulate it.
    Any thoughts?
    Thks
    2003-10
    San Francisco CA
    1,190
    Default Re: convert blocks into data points
    Hi Maria,
    Please *note* I have moved your thread from the ACA - General forum to this one as I feel it will be better served here.
    As to your question, I'm not familiar with Land Development Desktop but will the DATAEXTRACTION command work for your needs.
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    TN/KY Area
    1,640
    Quote Originally Posted by stelthorst View Post
    Hi Maria,
    I don't think the Data Extraction is in the 2i version (2000i). I don't have that old version loaded any longer but later versions had a block to point function IIRC.
    You can try the map query report to write out the block data or even the old attext command then import that text file as a point file maybe.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    2011-12
    5
    No problem Stelthorst.
    Jmurphy, I tried the command but it extracts only attributes.
    TN/KY Area
    1,640
    Using ATTEXT you can get the block x, block y cordinates with the template file.
    Using the map query you can also get those from the object property.
    J. Murphy
    AKA
    Murph
    2011-12
    5
    Thank you all very much for your answers.
    To Jmurphy, the map query did the trick. It worked very well, thanks.
  1. Converting blocks with object data to Civil3d points (2008)
    By tcapmusic in forum AutoCAD Civil 3D - General
    Last Post: 2008-07-02, 10:12 PM
  2. How to convert dynamic blocks to static blocks
    By moonlight_9630 in forum Dynamic Blocks - Technical
    Last Post: 2008-06-12, 05:10 AM
  3. Convert Points from CMM
    By Jack Cheong in forum AutoCAD 3D (2006 or below)
    Last Post: 2007-10-21, 07:43 PM
  4. Base points in Blocks not behaving when I make Blocks use annotative scale
    By dood in forum AutoCAD Land Desktop - General
    Last Post: 2007-06-10, 04:51 PM
  5. Replies: 6
    Last Post: 2006-06-20, 12:28 PM
