Thread: Run-time error '429' (ActiveX component can't create object)
    2011-10
    39
    Default Run-time error '429' (ActiveX component can't create object)
    Hi, I've recently tried to convert some code over from using a custom control to use ActiveX CommonDialog API. It works fine on my computer but when updated on clients computers they are given the error listed in the title. Not sure what I'm missing. Thanks for any help.
    Turlock, CA
    5,745
    Default Re: Run-time error '429' (ActiveX component can't create object)
    They don't have that control installed. Some controls are not part of the vba redistributable license and get installed by other programs. You can use acad's file dialog and a few others like the color picker. Which one do you need?
    C:> ED WORKING....
  1. ActiveX component can't create object
    By jkp in forum VBA/COM Interop
    Last Post: 2014-11-19, 08:50 PM
  2. Replies: 6
    Last Post: 2009-11-12, 03:32 PM
  3. Replies: 3
    Last Post: 2006-12-26, 03:59 AM
  4. Replies: 2
    Last Post: 2006-08-04, 03:22 PM
  5. Replies: 7
    Last Post: 2006-07-24, 08:57 AM
