Thread: import and edit built-in autodesk subassembly in subassembly composer??
    2010-11
    2
    Default import and edit built-in autodesk subassembly in subassembly composer??
    hi guys.
    i want to know how can i import built-in (autodesk designed) subassemblies in subassembly composer?
    is it possible to use subassembly .dll to convert in .ptk format and import it in subassembly composer?
    i want to modify built-in subassemblies.
    2015-12
    Arizona
    2,402
    Default Re: import and edit built-in autodesk subassembly in subassembly composer??
    I would suggest you do this in a working file, as what you are attempting to do is not the purpose or function of the Sub-Assembly composer as I undertand it.
    Civil Engineering Moderator civil3Dguide's Avatar
    2006-01
    Temecula, CA
    281
    Go to the insert ribbon tab, on the import panel expand the drop down on the bottom and select import sub-assemblies. Browse to the file location and select it.
    2010-04
    4
    The question is referring to how one can insert pre-made subassemblies from Civil 3D in order to EDIT the existing subassemblies. This would also help with actually understanding how new custom subassemblies need to be laid out. Is there a way to IMPORT an existing Civil 3D subassembly into the Subassembly Composer. If it wasn't intended for the Composer to be an Editor, I'm pretty sure this needs to be accomodated for at some point. Section 3D is far superior as far as I can tell. Maybe Civil 3D needs to cough up some dough and buy Section 3D? (No i'm not a Section 3D salesman, I just seen it in action in a very complex context.)
  1. 2013: Subassembly Composer and Marked Point
    By WScottAllenPE in forum AutoCAD Civil 3D - Corridors
    Last Post: 2013-09-24, 05:06 PM
  2. 2012: Autodesk Subassembly Composer 2012
    By danielogallegos619936 in forum Español - AutoCAD Civil 3D
    Last Post: 2013-04-06, 05:35 AM
  3. 2013: Autodesk Subassembly Composer 2012 Parte II
    Last Post: 2012-07-16, 11:47 PM
  4. AUTODESK SUBASSEMBLY COMPOSER COMO CARGARLO Y VISUALIZARLO
    By tpn2012441249 in forum Español - AutoCAD Civil 3D
    Last Post: 2012-04-26, 07:43 AM
  5. Subassembly Composer
    Last Post: 2011-10-12, 12:32 PM
