Hello everyone!
I've got what I hope to be an easy problem. We use a lisp routine that can match attributes from one block to another (below). If you change the attributes of a block, it matches those attributes to other blocks through the entsel function. It works well, but I was hoping I could streamline it a bit.
Anytime we change a block, the other blocks we want to match all have the same tag (ITEM_NUM). So, if we change the part/model numbers, etc. of a block with the ITEM_NUM of "5", then the blocks we need to match will also have the same ITEM_NUM attribute of "5".
I trying to modify the code to simply look for all the other blocks with the same attribute in the ITEM_NUM tag and change the rest of the attributes to match, without having to individually select each block.
Any guidance/direction would be great!
Thanks!
Here's the code I'm working with:
; This returns a list of tags and thier values that are in the desired block
(defun gettaglist ( ent / eg taglist )
(while (and
(setq ent (entnext ent) eg (entget ent))
(not (= "SEQEND" (CDR (ASSOC 0 EG))))
(if (= "ATTRIB" (cdr (assoc 0 eg)))(setq taglist (cons (cons (cdr (assoc 2 eg)) (cdr (assoc 1 eg))) taglist)))
taglist
);d
; this will apply a list of tag values to a desired block.
(defun applytaglist (taglist ent / eg origent)
(while (and
(if (and
(assoc (cdr (assoc 2 eg)) taglist)
(entmod (subst (cons 1 (cdr (assoc (cdr (assoc 2 eg)) taglist))) (assoc 1 eg) eg))
(princ));d
(defun c:CopyAttributetoblocks ( / taglist kwordstring answer)
(setq kwordstring "")
(initget 1 (foreach n (setq taglist (gettaglist (car (entsel "\nSelect block of source Attribute" ))))
(setq kwordstring (strcat kwordstring " " (car n)))
(setq kwordstring "[")
(if (setq answer (getkword (strcat (foreach n taglist (setq kwordstring (strcat kwordstring (car n) " \"" (cdr n) "\"" "/"))) "]:")))
(progn
(setq taglist (vl-remove-if-not '(lambda (x) (= answer (car x))) taglist))
(princ "\nSelect blocks to copy attribute to:")(princ)
(foreach ent (mapcar 'cadr (ssnamex (ssget)))
(applytaglist taglist ent)
(princ))
(defun c:MatchAtts ( / taglist )
(princ "\nSelect blocks to apply attributes to")(princ)
(setq taglist (gettaglist (car (entsel "\nSelect Source Entity for attributes"))))
(princ))
