Thread: 3D Clearances for MVparts
    2011-12
    Post 3D Clearances for MVparts
    Is there a way to Add 3D clearances to MVparts and have the ability to turn them on or off in a drawing? In other words a visibility state for MVparts.
    2007-11
    Dallas, TX - USA
    352
    Default Re: 3D Clearances for MVparts
    Quote Originally Posted by brenaud315971 View Post
    Can't do it with MvParts. I have only created a few parametric parts, not out of need but out of aspiration, and it seems you could have something that can function as clearance. Even then, it depends on the type of equipment you're modeling. And it can get WAY more complicated creating parametric parts.
    I always created a normal solid on a clearance layer and manually added them through my model (VAV or FPB access, larger valve handles, AHU maintenance requirements, etc).
    2007-10
    Tucson, Arizona
    613
    Yes you can in a sort of round-about way. You can edit the "Symbol" block of the mvpart and add the clearances on a "your-clearance-name" layer. After the mvpart is inserted, you can control whether those clearances are displayed by freezing/thawing the "your-clearance-name" layer you created.
    -Buzz
    2007-11
    Dallas, TX - USA
    352
    Good post Buzz, never knew that to be a possibility. Forgive my misleading post above!
  1. Cable tray clearances
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2014-11-13, 05:19 PM
  2. Door with ADA Clearances
    By pwmsmith in forum Revit Architecture - Tips & Tricks
    Last Post: 2010-10-27, 06:46 PM
  3. Clash Detective - Clearances
    By J3F in forum NavisWorks - Wish List
    Last Post: 2009-06-11, 07:56 PM
  4. Clearances w/ Transparency
    By RevitNinja in forum Revit MEP - General
    Last Post: 2009-05-13, 05:59 PM
  5. Door w/ Clearances
    By PaperStreet SoapCO in forum Revit Architecture - Families
    Last Post: 2007-09-13, 08:38 PM
