Thread: Params in revision deltas
    2009-03
    77
    Default Params in revision deltas
    I'm trying to add a few instance parameters into the standard revision delta as we want to add a little more text info. When loading the family into the project, the new properties are not available in the properties window.
    If I add a few lines, the lines show up just fine, so I know the family is loading.
    Is there a limitation here in this type of family?
    THanks.
    2001-07
    Phoenix, AZ
    1,003
    Default Re: Params in revision deltas
    Yes. With some families, like the revision tag, you're not able to add parameters. Not sure why but there you go.
  1. Creating params
    By Jimbob in forum Revit MEP - General
    Last Post: 2011-04-07, 10:26 AM
  2. Question about revision clouds and deltas
    By rtaube in forum Revit Architecture - General
    Last Post: 2011-01-20, 04:12 PM
  3. IFC Params for BPMs
    By ekoehne in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-06-13, 09:24 PM
  4. Managing yes/no params
    By revituser195 in forum Revit Architecture - Families
    Last Post: 2010-03-16, 12:26 AM
  5. Revision Clouds and Deltas
    By cstarr in forum Revit Architecture - General
    Last Post: 2005-08-23, 03:52 PM
