Thread: problem with move command
    2008-12
    24
    Default problem with move command
    When I use the "move" command and select an image to locate elsewhere on the drawing, all of the image will move except for one or two dimensions. The extension line extends along with the image, but remains anchored at it's original location along with the dimension. This occurs once in a while. I'm pretty sure I capture all of the image in the move window.
    0,0,0 The Origin
    8,570
    Default Re: problem with move command
    Is it actually an image or is it a collection of acad objects?
    The dimensions are not part of an image so need to be selected as well as the image for the move command.
    2009-01
    B5
    544
    Is it possible that the Z coord is different on that end?
    100 Club JeffClark's Avatar
    2002-07
    South Jersey
    152
    Sounds like the dim is "Associative". When you move the object it is associated with, the dim compensates. Happens all the time. We call it "Jumping Dims".
    Just highlight the dim, and relocate the Jumped node using the grips.
    You can turn off associated dims, but the benifits of associated dims are far greater than an occiasional Jumper.
    See "Associative Dimensions" in the help.
    TN/KY Area
    1,640
    Defpoint and/or layer 0 locked or turned off.
  1. USE MOVE,COPY,ROTATE,SCALE COMMAND IN ONE COMMAND
    By cadsoft in forum AutoCAD Tips & Tricks
    Last Post: 2011-03-14, 02:47 PM
  2. Problem with Revit MEP and the move command and using contrain
    By Ken.drewnowski in forum Revit MEP - General
    Last Post: 2009-06-03, 08:38 PM
  3. Copy and Move command selection problem
    By smckee in forum AutoCAD General
    Last Post: 2008-09-05, 05:03 PM
  4. move command
    By richelleharp in forum Revit Architecture - General
    Last Post: 2006-11-28, 03:52 AM
  5. Dimension points do not move when using the Move command
    By sudhirkizhakoote in forum AutoCAD General
    Last Post: 2005-10-16, 05:33 PM
