Thread: Layers & Display Configurations
    2015-10
    30
    Question Layers & Display Configurations
    Does anyone know a way to turn layers off or on using the Display Configurations?
    I am trying to create a presentation or brochure drawing of our houses without creating an additional file. I'm thinking I should use display configuration for this, but I am not sure how to turn off unwanted layers when I switch the configuration.
    For example; display configuration is set to Standard and I see everything I need for construction documents. Potential customers don't want to look at the dimension strings and joist locations so I would like to create a marketing type of floor plan. The 'Presentation' display configuration works good, but it leaves all of my dimensions and notes on the plan which I would like removed in that display configuration.
    Is there any way to accomplish this?
    2003-03
    Philadelphia, PA
    2,392
    Default Re: Layers & Display Configurations
    Unless you are using AEC dimensions, which can be controlled by the Display System, I do not know of a way to have a layer state (or any other means of setting layer on/off or freeze/thaw status) associated with a Display Configuration.
    If you are good at creating a reactor-based customizations, you could set one up that would trigger a routine to turn off the unwanted layers when you change the Display Configuration to Presentation. Or you could set up such a routine that would have to be manually run when changing the Display Configuration.
    Are you setting up a separate Layout and viewports to create the presentation brochure? If so, a reactor program may be more than you really need; having a presentation layer state that you can set active in the viewport, along with the Presentation Display Configuration may be enough.
  1. ME31-2: Display Configurations for MEP Design
    By Autodesk University in forum Mechanical Design
    Last Post: 2013-04-17, 04:45 AM
  2. 2011: Layers frozen in viewport still display, still plot
    By smeyer in forum AutoCAD General
    Last Post: 2012-04-17, 06:24 PM
  3. Display Problem with Layers
    By dguinan in forum AutoCAD General
    Last Post: 2008-11-15, 08:04 AM
  4. Replies: 1
    Last Post: 2008-06-17, 10:24 PM
  5. Controlling the display of Xref Layers
    By chillme1 in forum AutoCAD General
    Last Post: 2007-03-14, 10:23 PM
