Thread: I wish that in the properties Palette you can select via a drop down if text is Multiline, Single line or Attribute.
    Wish List Administration
    2011-08
    4,581
    Default I wish that in the properties Palette you can select via a drop down if text is Multiline, Single line or Attribute.
    Summary: Text Type
    Description: I wish that in the properties Palette you can select via a drop down if text is Multiline, Single line or Attribute. The Palette would automacily change to suite the requirements and differences between the various text types.
    Product & Feature: AutoCAD
    Submitted: Tue, 03 Jan 2012
    Cairo - no, not Illinois
    4,859
    Default Re: I wish that in the properties Palette you can select via a drop down if text is Multiline, Single line or Attribute.
    I'm not understanding what this request is asking for? If you've selected an annotation, be it a TEXT entigy or an ATTRIB entity, then the Properties palette reflects that selection. If you've selected multiple annotations, then the pull-down on the properties lets you narrow down to type of object.
    Or is this a wish to (A) change object types from TEXT to MTEXT to ATTRIB etc.?
    2015-10
    68
    This a wish to change object types from TEXT to MTEXT to ATTRIB etc.?. Hope that clarifies!
    4,859
    yeah, that helps. and no, i don't think it's a usable addition. Especially ATTRIBS. they never exist alone, but only as part of a block instantiaion. so how could you change a meaningful text string into a usable ATTRIB? first have to create an ATTDEF entity, populate it with all appropos settings, then create a block instance - and then insert the block instance.
    I could sorta see this for TEXT to MTEXT and vice versa, but there are already ways to do that that give me better control. (txt2mtxt, explode).
  1. Replies: 11
    Last Post: 2019-01-09, 09:55 AM
  2. turn single line of attribute text into two lines
    By JRBOURNE in forum Dynamic Blocks - Technical
    Last Post: 2009-12-23, 04:40 PM
  3. TEXT - Single to Multiline
    By Hotpants Longbottom in forum AutoCAD General
    Last Post: 2008-08-27, 09:26 PM
  4. AutoCAPS for Single Line and Attribute Text
    Last Post: 2007-11-09, 06:55 PM
  5. Single line Text or Multiline Text
    By Spenner in forum AutoCAD General
    Last Post: 2006-06-02, 11:21 PM
