Thread: display framing member end connection forces
    2011-05
    2
    Default display framing member end connection forces
    Hi all,
    still exploring Revit (learning new tricks every day), but I'm stumped how to display a framing members analytical information (beam end connections), which i know from the palette that are in the model.
    I've tried making a new family member of a structural framing tag, which seems okay, but then when i use the beam annotation button and try to add the tag at the beam ends, it wont load in.
    surely manually entering the forces is a giant leap backwards......
    any help greatly appreciated.
    thanks
    Andy
    2009-01
    57
    Default Re: display framing member end connection forces
    Did you attempt modifying and existing tag and just create a new type that displays the desired information?
    2007-01
    226
    There should be two tags in annotations structural library, named
    Structural Framing Tag-Start Reactions.rfa
    and
    Structural Framing Tag-End Reactions.rfa
    Load both of these tags then use the Beam Annotations tool.
    100 Club lzaras's Avatar
    2001-03
    United States, next to a Lake
    136
    Quote Originally Posted by dmahan View Post
    and
    Along with dmahan's procedure, I've also edited my tags; Structural Framing Tag-Start Reactions.rfa, I've made to be a dark green text and Structural Framing Tag-End Reactions.rfa, I've made to be a dark red text. This way, when I'm looking at a plan view, I can automatically see which end of the beam is the start end and which end is the end end. (Unfortunately will not be helpful for color-blind folks.)
    As far as inputting all the reactions... If you brought the model in from an analysis program like RAM, the reactions will be associated with the beams. If you placed the beams yourself, you'll need to make sure the reactions are available to you through the Project Parameters (I've added a pic below of a project that had the reactions come in from RAM) and you will need to manually give all the beams their start and end reactions. Though if you have a bay of beams with the same start/end reactions, you can choose several beams at a time to give them all the same values (in the properties palette.)
    2008-01
    3
    The framing reactions that come in from the tag usually round down if the value is less than .5. Is there a way to have all values round up? Typically we never round down for reactions.
  1. VB for Excel API not Extracting Peak Member Forces from Robot
    By RoboExploiter in forum Robot Structural Analysis
    Last Post: 2011-09-05, 08:03 AM
  2. Beam / Framing Member origin
    By djc1984 in forum Revit Architecture - General
    Last Post: 2010-09-08, 03:37 PM
  3. framing member joins
    By kathy71046 in forum Revit Structure - General
    Last Post: 2009-01-29, 05:29 AM
  4. 3D Framing Member Tool Palettes
    By cadkiller in forum ACA General
    Last Post: 2006-08-10, 04:42 PM
  5. Creating a hole in a structural framing member.
    By studio3p in forum Revit Architecture - General
    Last Post: 2004-09-03, 01:17 AM
