Thread: view filter for conduit size
    2015-11
    Baltimore, MD
    46
    Default view filter for conduit size
    I did a quick search through the forums and did not find anything already posted about this.
    I'm in Revit MEP 2011, and I want to apply a view Filter to conduit runs below a particular diameter. I am using the "Size" system parameter in the filter so that I can apply it to both Conduit and Conduit Fittings.
    In the Filter Rules:
    Filter by: Size
    is less than
    1.5
    I placed two conduit runs, one whose Size parameter 1 1/2" diameter for both the Conduit objects and the Conduit Fittings, and another at 1 1/4" diameter.
    The filter seems to either apply or not apply to both runs, regardless of what number I enter in the filter. The filter applies for any value I enter down to 1.1. When I set the number to 1, the filter no longer applies to either run.
    I asked around the office, and everyone agreed that 1 < 1.1 < 1.25 < 1.5
    Am I doing something wrong?
    Thanks in advance.
    2007-01
    Suwanee, just north of Atlanta
    160
    Default Re: view filter for conduit size
    This is ugly indeed. The problem is the SIZE value is not treated as a "length" and therefore cannot be used as a value to compare. To get what you are after you will need to work out both positive filters working with negative filters, something like:
    Size contains 2"
    Size does not contain / (example, so that the 3 1/2" isn't grabbed)
    I had a hospital where I wanted to do the same thing. It took a while of tweaking, but I did get it to work for my specific environment.
    Good tip, thank you.
  1. Conduit Size Parameter based on the number of wires in the circuit.
    By autocad.wishlist1734 in forum Revit MEP - Wish List
    Last Post: 2017-11-01, 04:11 PM
  2. vertical conduit circle size in medium view
    By Ning Zhou in forum Revit MEP - General
    Last Post: 2012-07-05, 09:09 PM
  3. Panel Schedules - Wire and Conduit Size
    By heiko.stugg in forum Revit MEP - Families
    Last Post: 2011-02-18, 04:24 PM
  4. Conduit Size
    By cparvez in forum AMEP General
    Last Post: 2009-12-13, 10:39 PM
  5. MEP CONDUIT SIZE
    By andrzej_makaruk in forum AMEP General
    Last Post: 2007-09-13, 06:30 PM
