Results 1 to 6 of 6
Thread: huge problem intersection
    2011-06
    Default huge problem intersection
    Hello Civil 3d users,
    will you please please help me with intersection design of my project, if you could please see the attached file of my project. in this drawing what I noticed that, the big problem was in curb return, and also I found strange grade changes in Road B profile ( which is secondary road with intersection Road A), I also want you guys to tell me why this big change in grade happened ?
    to be honest I just started working with civil3d a few days ago and I don't know more about it, and what I learnt about civil 3d, only from civil3d manual.
    thanks in advance
    2004-05
    49
    Default Re: huge problem intersection
    I tried to download this file, but it stopped at 500kb and said it was finished.
    if the file is 2011 or older send to me at my email dgordon at priennewhof dot com.
    2015-12
    Arizona
    2,478
    before I open the file; my guess is you either did not assign profiles for your curb return assemblies to use,
    or the softare (intersection wizard) failed you. The last part would be why I 'still' teach my students how to create an intersection without using the wizard. More Later....
    2015-12
    Arizona
    2,478
    I'm not totally sure what your design intent was here; however it looks like you chose the WRONG profile for Road A. Unless using the RT-Ditch profile is what you wanted to do.
    Next I would suggest examining your assemblies and the cut fill slope parameters and targets for those regions.
    2015-10
    Texas
    66
    Did you profile the roads or ditches? Im a little confused also. What are the ditches targeting. It say it is targeting a ditch profile. Did you allow C3D to create profiles for the curb returns?
    tony
    CAD Manager
    www.tonyscivil3dworld.blogspot.com
    2015-12
    Arizona
    2,478
    I'm pretty sure this was a simple targeting issue, the lack of follow up by the original poster would indicate the issue has been resolved.
  1. 2004: File got HUGE and HUGE-ER - Design Center to Blame?
    By fkellogg in forum AutoCAD General
    Last Post: 2012-05-02, 01:33 PM
  2. problem with CAD link - it shows up HUGE!!!
    Last Post: 2009-09-17, 06:01 PM
  3. Replies: 3
    Last Post: 2008-10-01, 08:43 AM
  4. Autocad Installation HUGE problem
    By diyas in forum AutoCAD General
    Last Post: 2008-02-11, 04:19 AM
  5. Intersection problem
    By nvphatbk in forum Revit Structure - General
    Last Post: 2007-12-14, 12:02 AM
