Thread: Xref to DWG Association (dependency)
    2012-01
    4
    Default Xref to DWG Association (dependency)
    Hello All!
    Is it possible to open a known Xref DWG and see what DWGs are using it as an Xref? This is basically the reverse of opening a DWG and looking at the External Xref dependencies. I want to open the Xref/DWG and see a list of all DWGs that use this particular file as an Xref.
    Thinking that this would probably have to be done using a macro/script, but perhaps there's a feature within 2012 for which I'm unaware?
    Thanks in advance!
    Clint
    Cairo - no, not Illinois
    4,842
    Default Re: Xref to DWG Association (dependency)
    use the Standalone ReferenceManager utlity installed with Acad.
    2012-01
    4
    Thanks for the quick reply.
    The Reference Manager is a great tool for seeing what Xrefs are assigned/associated with a given DWG, but I'm looking to do the inverse of this.
    Example:
    Currently the Reference Manager shows that Xrefs X, Y & Z are assigned to DWG "A". I'm looking to find what drawings (such as "A" et al) specifically use Xref "X".
    Clint
    100 Club reikajapan's Avatar
    2007-11
    102
    Do this with Design Center, Search function, use the drop down list 'Look for' and pick Xrefs, then pick a location to search, finally type in the name of the file in the 'search fr the name'' area.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Thanks reikajapan. That is a very useful tip.
    Jeff Paulsen
  1. Dependency ViewTemplates
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2015-08-30, 02:29 PM
  2. Cascading Surface Dependency Control
    Last Post: 2014-11-18, 02:45 AM
  3. AutoCAD 2010 acmgd.dll dependency
    By hlusiakov580562 in forum Dot Net API
    Last Post: 2014-08-20, 09:11 AM
  4. What really is a cyclic dependency? - make the modeling more flexible.
    Last Post: 2013-01-30, 08:20 AM
  5. Dependency Loop Problem
    By stusic in forum 3ds Max - General
    Last Post: 2009-08-19, 04:47 PM
