Results 1 to 7 of 7
Thread: Display Missing "Layer-Locked-Icon" on Screen
    Member sckw1306364165's Avatar
    2011-11
    4
    Question Display Missing "Layer-Locked-Icon" on Screen
    Hi. Hope you all can help ...
    Just having an odd problem ...
    Normally when a layer is locked, you hover your cursor over the
    locked layer on screen you will be able to see a small [Lock Pad]
    kinda icon ...
    But recently mine doesn't ... I tried looking through the HELP and
    search online for similar cases, but no avail ...
    { Please refer to the attach image for explanation ... }
    If any of you might have similar problem and know the solution ...
    Please help ... Many Thanks ...
    * Btw ... I'm using AutoCAD 2012 ...
    ... Steven.CKW ... From Singapore (SG) ...
    100 Club Julesagain's Avatar
    2005-06
    Atlanta
    116
    Default Re: Display Missing "Layer-Locked-Icon" on Screen
    I think you have to have a command active to see the little lock icon.
    2011-11
    4
    Quote Originally Posted by Julesagain View Post
    Hi ... I tried commands : "Move". "Erase", "Copy" and etc ... but the [Lock Pad] Icon still not appearing when the cursor hover over the Locked Layers ...
    Anyone else has similar experience and know what to do to recover back that [Lock Pad] icon ???
    100 Club heinsite's Avatar
    2005-11
    Kona, Hawaii
    138
    Not on my system at least... running LT 2012 here and the padlock icon shows up anytime the cursor is moved over an object on that layer. No command was active.
    Dave
    2011-11
    4
    Arrow Re: Display Missing "Layer-Locked-Icon" on Screen
    Hi. Need to bring this topic up again ...
    No solution so far ...
    Is there anyone can help ??
    2011-11
    4
    Lightbulb Re: Display Missing "Layer-Locked-Icon" on Screen
    Hi ... To whoever reading this Post ...
    I got the solution from Autodesk > Discussion Groups ...
    * Link below ...
    http://forums.autodesk.com/t5/AutoCA...n/td-p/3311775
    Anyway ... it has solved ...
    2005-11
    Kona, Hawaii
    138
    Patchy is a great source of info over there. Glad you found this. I learned something too!
    Dave.
  1. 2014: Missing 'Design Center" icon or button
    By robotgrass in forum AutoCAD Mechanical - General
    Last Post: 2014-08-25, 05:41 AM
  2. 2012: Tool Palette Button Properties: "Layer" is missing!
    By michael.torrey566477 in forum AutoCAD Customization
    Last Post: 2013-09-24, 05:38 PM
  3. 2012: Revit Icon "R Logo" in top left screen errors (Not blackout error)
    By rbcameron1 in forum Revit Architecture - General
    Last Post: 2012-09-27, 01:42 PM
  4. "Unable to Write Data to Locked Layer: XREF"
    By BlackBox in forum AutoLISP
    Last Post: 2010-08-03, 12:25 AM
  5. Constant "Unable to write data to locked layer" messages
    By sinc in forum Land Desktop - General
    Last Post: 2006-02-08, 08:12 PM
