does anyone know the lisp that allows you to select several lines or polylines and adds the total linear length
Welcome to AUGI!
Here's one I wrote a while ago:
Edit - This will count the total length for Arcs, Lines, and *Polylines.Code:(defun c:LENT () (c:LengthTotal)) (defun c:LengthTotal ( / ss) (princ "\rLENGTH: TOTAL ") (vl-load-com) (if (setq ss (ssget "_:L" '((0 . "ARC,LINE,*POLYLINE")))) ((lambda (i / o) (vlax-for x (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (cond ((vl-position (setq o (vla-get-objectname x)) '("AcDbLine" "AcDbPolyLine")) (setq i (+ i (vla-get-length x)))) ((= "AcDbArc" o) (setq i (+ i (vla-get-arclength x)))))) (prompt (strcat "\nTotal Length >> " (rtos i 2 2))) (vla-delete ss)) 0) (prompt "\n** Nothing selected ** ")) (princ))
HTH
Computer Specs:
Thanks! I've been out of the design for a few years but now I'm back in it. New Year = New Goals...
Thanks for the lisp, I'll try it out.
Computer Specs:
@RM:
Also, there's no reason to filter out objects on locked layers.Code:(vlax-curve-getDistAtParam <ename> (vlax-curve-getEndParam <ename>))
Computer Specs:
Computer Specs:
Computer Specs:
