Thread: Converting DWG to either IGES or STEP files
    Default Converting DWG to either IGES or STEP files
    Hi all,
    I must be under-gifted but I cannot manage to convert dwg files to step or iges file (dwg files enclosed). Can someone help me for that?
    Thanks a lot!
    Anotine
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default Re: Converting DWG to either IGES or STEP files
    Command "stepout"
    BTW, can you post your question to "AutoCAD General" Forum next time?
    Here is the place for people to share their tips & tricks.
    Thanks a lot for your answer BoKirra and sorry for using the wrong forum!
    I have been looking for it and I don't have any "stepout" command in my version of Autocad... Do you know an other way to export step or iges files?
    Thanks again!
    Antoine
    0,0,0 The Origin
    8,570
    The IGESout ability was removed from vanilla acad many releases ago. The Mechanical version still has it (AFAIK) and Inventor has it. Any modern modeller software that can read .dwg files will almost certainly do it.
    If this is a one-off, go to the Manufacturing forums and ask if someone will do it for you.
  1. 2011: Import .iges & .step files in Revit
    By swapr78 in forum Revit MEP - General
    Last Post: 2013-04-17, 05:26 PM
  2. converting IGES files
    By Bowen_lee2 in forum Inventor - General
    Last Post: 2012-02-08, 04:55 PM
  3. IGES and STEP support to AutoCAD
    Last Post: 2010-07-08, 06:24 PM
  4. Converting DWG to either IGES or STEP files
    By LA_Girl in forum AutoCAD General
    Last Post: 2009-08-24, 06:52 PM
  5. IGES and STEP dialog boxes have disappeared
    By thare in forum AutoCAD General
    Last Post: 2006-02-01, 02:52 AM
