Thread: Civil 3D crashs
    2011-09
    Pittsburgh
    7
    Cool Civil 3D crashs
    Hey All, I'm using Civil 3D 2007 and have been since its release. Awhile ago it started taking about 10 minutes to load and I hadn't even opened a drawing yet. Now its just gets realy slow and will lock-up at no perticular command. It won't even let me use the taskmanager to get out of drawing. I'm using a Dell 390 work station, harddrive is only about 1/4 full, have 2 G's of ram. I can't figure out why its running so slow and had gotten progressively worst. Any ideas
    Earth
    9,805
    Default Re: Civil 3D crashs
    Well, my gut reaction is "Civil 3D 2007? Really?".... but according to your information, you have been running it a while... then something else has changed.
    The first thing I would check is the status of the %temp% directory. Verify what location C3D/AutoCAD is using for temp (Options, Files, Temporary Drawing File Location), then browse to this location using Windows Explorer and check the number of files/folders present. Clean this out if needed. I have seen this location get thousands of files and it does have some effect on C3D/AutoCAD performance.
    Anything else changed recently with your system, the network, or anything else? Installed anything lately? Have you tried restoring a system restore point?
    R.K. McSwain | CAD Panacea |
    2011-09
    Pittsburgh
    7
    LOL, I have 2010 but not a machine to run it on yet!
  1. 2014: Civil 3D 'shared reference point tool' and 'Integration with Civil 3D' revit extension problem?
    By alex.bell.252970 in forum Revit Structure - United Kingdom
    Last Post: 2013-11-26, 02:15 PM
  2. Replies: 0
    Last Post: 2013-04-17, 04:22 AM
  3. Se puede instalar civil 3D 2009 y civil 3D 2010 en un mismo Windows
    By wuari in forum AutoCAD Civil 3D - General
    Last Post: 2009-11-22, 03:27 AM
  4. Webcast for Civil Engineers: Introduction to AutoCAD Civil 3D 2008
    By Brogueira-CADptbr in forum AutoCAD Civil 3D - General
    Last Post: 2007-02-26, 10:34 PM
  5. Civil 3D 2007 - How does file structure and standards relate to Civil 3D
    By eleonard in forum AutoCAD Civil 3D - General
    Last Post: 2007-01-22, 06:05 AM
