Thread: Options Dialoug Box-no show
    2009-02
    Maryland
    12
    Default Options Dialoug Box-no show
    Hey guys, hoping someone could help with this issue. I've noticed on my AutoCAD MEP 2012 that anything to do with the options dialog box doesn't work. When i go into the options nothing happens, i have to hit the escape key to get the courser back. Any way i go into it weather it be type in "options", "op", or go to the "tools" drop-down and go to "options" i get the same result...Nothing. I've tried undefining and redefining the "options" command and that has not helped. I have also done a repair of AutoCAD MEP 2012 installation and nothing as well. Hopefully someone has seen this problem before.
    Thanks,
    2,095
    Default Re: Options Dialoug Box-no show
    Possibly offscreen. Try these, in sequence:
    1. ALT+SPACEBAR
    2. M key
    3. Any arrow key
    4. Move mouse, dialog should appear at cursor.
    9,805
    Exclamation Re: Options Dialoug Box-no show
    ...and if it helps to see that in action, take a look at http://cadpanacea.com/node/95
    2009-01
    B5
    544
    ...and do you not need to start the sequence by typing OPTIONS at the Command line?
    2,095
    Quote Originally Posted by clshade View Post
    OK, Ok...
    2009-02
    Maryland
    12
    That worked great! Thanks guys!
  1. Replies: 0
    Last Post: 2011-11-17, 02:45 AM
  2. 2012: Mtext - how to not show formatting options.
    By WilliamA in forum ACA General
    Last Post: 2011-11-02, 04:12 PM
  3. How to show plan options
    By bill.92885 in forum Revit Architecture - General
    Last Post: 2006-09-19, 03:27 PM
  4. Replies: 2
    Last Post: 2006-05-18, 01:39 PM
  5. "show all warning messages" is grayed out in Options System tab
    By matthewmiller in forum AutoCAD General
    Last Post: 2005-06-24, 06:20 PM
