Summary: Allow pasting the path for existing drawings when creating a new sheet set
Description: When you create a new sheet set from existing drawings, when you get to the file dialog box that allows you to choose the directory, you have to navigate to the the folder instead of being able to type it, or paste it. This can be time consuming depending on where the last one you chose was relative to where the new one is. This would be a simple fix by changing the file dialog box used to the one used for open/save in autocad. Then shortcuts would be available also.
Product & Feature: AutoCAD
Submitted: Wed, 25 Jan 2012
