Results 1 to 6 of 6
Thread: Changing attributes color bylayer...?
    2007-10
    44
    Default Changing attributes color bylayer...?
    Hi Folks,
    How can I change attributes color to bylayer on a global method, I have a punch of panel schedules the the color is set and I need to change color bylayer. Normal I have to pick each attribute to make the change but each panel has 20 attributes x 20 panel schedule means alot of time.
    Is there a global command to do all at once...?
    I use Autocad 2011 LT.
    Thanks in advance
    2007-10
    44
    Default Re: Changing attributes color bylayer...?
    Found a solution:
    Used REFEDIT then ATTSYNC.
    Using these two commands changed the attributes color to bylayer globally.
    2009-01
    B5
    544
    Thanks for the tip and follow up
    2001-12
    Dallas, TX
    229
    BATTMAN command then ATTSYNC also works (and better IMHO).
    2012-05
    2
    So I've gone into the block I have and went to properties - color - bylayer... it is staying black (layer is on color 240). I go back into the block and try to do color "240" - its still black. In the main file I do "battman" and try to change the color to 240... no change!! What is going on? This works fine when its text but when its an editable attribute/label it isn't working for me.
    Quote Originally Posted by aport View Post
    Hi Folks,
    Thanks in advance
    Turlock, CA
    6,421
    Editing a block doesn't affect existing attributes. This is by design. Try running BATTMAN command.
    C:> ED WORKING....
    LinkedIn
  1. Change Attributes to color ByLayer
    By rmk in forum AutoCAD General
    Last Post: 2008-01-22, 12:24 AM
  2. How to change block w/ attributes bylayer
    By aport in forum AutoCAD General
    Last Post: 2008-01-16, 04:59 AM
  3. Replies: 10
    Last Post: 2007-05-06, 08:18 AM
  4. Changing all to Bylayer
    By Patriiick in forum AutoCAD Tips & Tricks
    Last Post: 2005-12-10, 03:07 PM
  5. Changing block entities' color to bylayer
    By sifuentes in forum AutoCAD General
    Last Post: 2004-11-12, 04:44 PM
