Thread: Electrical Circuit Tags-Problem
    2010-02
    24
    Exclamation Electrical Circuit Tags-Problem
    Have any one a solution for this problem (shown in the joined picture)
    2005-12
    53
    Default Re: Electrical Circuit Tags-Problem
    What is the problem, are you expecting the wire to be tagged: EF-F/7,30 ?
    2010-02
    24
    Thumbs up Re: Electrical Circuit Tags-Problem
    No i want that the mechanical equipment will be tagged in one Circuit EF-F/7 and with only one arrow.
    2006-08
    636
    in this case, you should use tag instead of wire, and choose one of Leader Arrowhead in tag type properties.
  1. Replies: 3
    Last Post: 2014-11-17, 05:09 PM
  2. 2013: Electrical Functionality (UK Base) Circuit refs
    By live4ever42 in forum Revit MEP - General
    Last Post: 2013-10-29, 01:46 PM
  3. 2014: Electrical panel circuit issue
    By neb1998 in forum Revit MEP - General
    Last Post: 2013-06-24, 03:43 PM
  4. Add field to electrical circuit for feeder.
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2012-10-13, 03:08 PM
  5. 2012: Electrical Circuit Line Type
    By Binu Mathew in forum Revit MEP - General
    Last Post: 2012-03-15, 01:14 PM
