Results 1 to 9 of 9
Thread: *error* function bad argument type: stringp nil - from Pull-down menu macro
    Member csiress's Avatar
    Orlando, Fl
    28
    Default *error* function bad argument type: stringp nil - from Pull-down menu macro
    I have created a pull down menu with this line in it.
    ID_CAS2 LISP [HATCH FIX]^C^C(setenv "MaxHatch" "1000000")
    However, this error occurs: error: An error has occurred inside the
    *error* functionbad argument type: stringp nil
    I am pretty certain that it's the quotation marks around MaxHatch and 1000000.
    How do I fix this? I really don't want to type (setenv "MaxHatch" "1000000") in the command prompt.
    Thank you for your help.
    Craig II
    13,656
    Default Re: *error* function bad argument type: stringp nil - from Pull-down menu macro
    Hi Craig
    Please note I have *moved* this thread from the AutoCAD Tips & Tricks forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    13,656
    Quote Originally Posted by csiress
    Hi
    Works for me.
    I Copied and Pasted...
    into a Custom menu file.
    Reloaded the Custom menu file.
    Clicked "HATCH FIX" from the Custom menu pull-down area.
    Environment variable MaxHatch was correctly set to 1000000 ( without any errors reported ).
    Is it possible to post an example menu file ( as an attachment ), that demonstrates the behaviour you see at your end...
    Have a good one, Mike
    9,802
    The error you quoted *error* functionbad argument type: stringp nil occurs because nil was passed to a lisp function expecting a string. It has nothing to do with your menu macro.
    When does this error occur? When the menu is loaded? Check the MNL file.
    If your menu is "custom.mnl", inspect "custom.mnl" for a lisp coding error.
    Orlando, Fl
    28
    Smile Re: *error* function bad argument type: stringp nil - from Pull-down menu macro
    Thank you for your help. I had placed the string in the MNS and that was causing the error. I placed the string in the MNU and reloaded and it worked without any issues.
    Again thank you.
    Craig II
    2011-08
    Auburn, CA
    18
    I get something very similar but it happens every time I load CAD. This is what I get:
    ; error: bad argument type: stringp nil
    It doesn't seem to cause any issues but it shows every time I load.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,633
    Kevin, when it displays at startup, it means there is a problem routine or function within one of your autolisp startup files.
    2011-08
    Auburn, CA
    18
    OK Opie here is the list of commands prior to the error:
    AcroPlot Command Loaded
    AutoCAD menu utilities loaded.
    Loading AcroPlot Commands
    AcroPlot Commands Loaded
    Command: _RIBBON
    Command: COMMANDLINE
    Command: TOOLPALETTES
    Command: properties
    Command: SHEETSET
    Command: Layer
    Command: EXTERNALREFERENCES
    Command:
    Command: ; error: bad argument type: stringp nil
    9,802
    Wink Re: *error* function bad argument type: stringp nil - from Pull-down menu macro
    Quote Originally Posted by LogoKevn View Post
    We cannot diagnose with just that info.
    Look at your startup LSP files, such as "acad.lsp", "acaddoc.lsp", "*.mnl" (where * is the name of any menu loaded), etc. Remove them from being loaded one at a time, until the problem goes away.
    More info here.
  1. VBALOAD error: bad argument type: stringp nil
    By jpaulsen in forum AutoLISP
    Last Post: 2011-11-09, 05:52 PM
  2. Replies: 7
    Last Post: 2010-02-05, 10:33 AM
  3. Replies: 4
    Last Post: 2009-05-22, 05:21 AM
  4. Replies: 8
    Last Post: 2007-01-03, 02:32 PM
  5. Replies: 6
    Last Post: 2006-12-07, 11:42 PM
