Thread: Synchronizing Annotavie MLeaders
    2015-12
    65
    Default Synchronizing Annotavie MLeaders
    Hi: Is there any way to turn on an automatic synchronization of annotative Multileaders so when you edit their position you don't have to do it manually each time?
    Thanks
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,102
    Default Re: Synchronizing Annotavie MLeaders
    I don't believe there is an automatic setting. You could create shorter key-in command for the ANNORESET command in your PGP file.
  1. 2014: Corridor NOT Synchronizing
    By DBill2508 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2013-10-16, 09:37 PM
  2. 2012: Electrical circuits disconnect when synchronizing
    By ModelBoss in forum Revit MEP - General
    Last Post: 2013-02-28, 06:58 PM
  3. Synchronizing with Structure
    By pat.walsh in forum Revit Architecture - General
    Last Post: 2010-12-01, 12:48 AM
  4. MLeaders
    By marble in forum AutoCAD General
    Last Post: 2007-08-01, 12:16 PM
  5. Synchronizing work on two computers
    By argh in forum CAD Management - General
    Last Post: 2005-10-21, 10:16 PM
