Results 1 to 6 of 6
Thread: draw a polyline relative to other objects
    2001-08
    5
    Default draw a polyline relative to other objects
    Hi all,
    I would like a function named "DynPlineCreator" to draw a polyline relative to other objects.
    1 - Selection of a line or polyline (live, on an Xref or block)
    2 - Selecting a starting point on the selected object.
    3 - Dynamic Input points as the great functions (CurveText, ObjectAlign ...) by Lee Mac.
    At each moment, options can be selected:
    - Option 1: Change of object.
    - Option 2: Continue the input by the ends lines or the vertices of a polyline.
    - Option 3: Free Entry of a point on the segments of the object (by the object snaps).
    Thank you in advance.
    2009-11
    5,522
    Default Re: draw a polyline relative to other objects
    Perhaps instead of placing an order as if this was a drive through (which AUGI is not), you might try coding your own routine, and ask for help when you get stuck with a particular aspect of the desired routine. Just saying.
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2004-08
    Hartford, Michigan
    3,194
    I thought I had seen this before. Check this out
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2020
    Windows 10
    2009-11
    5,522
    At least the OP waited a few days before duplicating the post. LoL
    *cough* Now, if only the OP would show some initiative, or effort, perhaps they would get some assistance. *cough*
    Computer Specs:
    2015-12
    383
    Sorry for the slight thread hijacking, but I just wanted to say how helpful people have been to me even when i posted the most basic functions of my code. (Even though it was nowhere near close to working)
    Thanks to al those have helped me from day one till now.
    (defun c:ty (/ code_text)
    (setq code_text "Thank you all")
    (alert code_text)
    (princ code_text)
    (princ))
    2004-08
    Hartford, Michigan
    3,194
    not sure I understand what the end goal is, but I would start here:
    (defun c:DynPlineCreator (/)
    (command "pline")
    ;clarification of the basic steps of program
    );_ end defun
    Windows 10
  1. Draw Polyline from list of points
    By LSElite in forum AutoLISP
    Last Post: 2015-04-21, 03:53 AM
  2. Replies: 1
    Last Post: 2015-04-10, 02:57 PM
  3. Replies: 5
    Last Post: 2009-02-26, 07:40 PM
  4. draw polyline on selected layer; help
    By ReachAndre in forum AutoLISP
    Last Post: 2007-10-03, 12:15 PM
  5. Moving Text Objects relative to base point as other Objects are moved / scaled
    By William Troeak in forum Dynamic Blocks - Technical
    Last Post: 2007-02-06, 02:35 PM
