Thread: Provide a new Block manager palette that streamlines working with blocks visually and is simliar to working with XREFS.
    Wish List Administration
    2011-08
    4,581
    Default Provide a new Block manager palette that streamlines working with blocks visually and is simliar to working with XREFS.
    Summary: Block Manager Palette - showing nested blocks tree, block properties, highlighting of blocks on screen when selected in the palette, renaming of blocks.
    Description: Key features:
    1) Tree style listing of blocks indicating all nested blocks
    2) Thumbnail image of blocks displayed for each block including the nested blocks. Simliar to the XREF palette where you can point at the XREF and it displays a thumbnail image.
    3) It would be nice if properties could be included or rather a choice of properties maybe even coordinates of each and every block on the drawing. Or how many instances of a particular block are in a given drawing. It could be combined with the properties pallette but I would like to see the entire list of blocks and see the nested structure and see thumbnails all in one dockable/collapsable palette.
    4) Highlight blocks on screen when block is selected on the palette.
    5) Ability to rename blocks or groups of blocks from the palette. Or maybe add a prefix to all instances of a block.
    Blocks are a major part of CAD and this would help every user identify blocks faster on drawings received from clients or other firms and determine if they are part of another block in a visual display rather than a mere list of names with no relation to each other indicated.
    Product & Feature: AutoCAD
    Submitted: Mon, 13 Feb 2012
    All AUGI, all the time clshade's Avatar
    2009-01
    B5
    544
    Default Re: Provide a new Block manager palette that streamlines working with blocks visually and is simliar to working with XREFS.
    Maybe a #6 would be to search for the instance of a block thru Design Center without having to call up each individual drawing.
    Edit: Never mind, figured that one out.
    Charles Shade AutoCAD LT 2014, Dynamic Blocks
    www.cshadedesign.com
  1. Xrefs.. working with different systems
    By marcoton411459 in forum CAD Management - General
    Last Post: 2013-10-25, 04:41 PM
  2. Create and Save Date Fields Working Through XREFs
    By Al Moroz in forum AutoCAD Fields
    Last Post: 2010-03-25, 12:43 PM
  3. Working with many big xrefs
    By Maverick91 in forum AutoCAD General
    Last Post: 2009-10-07, 02:16 PM
  4. Replies: 3
    Last Post: 2009-08-13, 03:58 PM
  5. Working with Visretain and Xrefs...
    By Chris Matira in forum AutoCAD Tips & Tricks
    Last Post: 2006-07-31, 05:50 PM
