Results 1 to 6 of 6
Thread: setting the plot style
    2003-11
    258
    Default setting the plot style
    i have created a lisp that does a number of things to clean up drawings like text styles, layers etc
    my issue is i want it to set the plot style. i have tried it through plot but it prints a copy. and page setup only comes up as a dialog box.
    any ideas?
    2009-11
    5,530
    Default Re: setting the plot style
    From memory... You can enter a "NO" option at the end of using the ._-plot command.
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    Super Moderator rkmcswain's Avatar
    Earth
    9,715
    You can push the -plot command as Renderman says, and you can directly access the layout using VLisp to set the plot style also.
    R.K. McSwain | CAD Panacea |
    2009-11
    5,530
    You know, a while back I had trouble with that albeit specifically during within an ObjectDBX function.
    The function iterated the directory of drawings successfully, removing all existing plot styles, and even added the replacement(s)... but (if memory serves) I still ended up requiring the -plot command to set the successfully imported style current within Page Setup Manager.
    Bye, bye ObjectDBX. LoL *shrug*
    Computer Specs:
    2003-11
    258
    i dont think im following you
    (command “ –plot” “no” )
    enters the non-detailed plot configuration
    or do write out all the steps with no at the end?
    (command “ –plot” "y" "" "" "" "" "" "" "" “no” )
    2009-11
    5,530
    Here's a snippet from an old routine, you may need to specify some of the parameters that I've used the default (i.e., "") below:
    (vl-cmdf "._-plot" "_n" "layout" "YourPageSetupNameHere" "" "" "_y" "_n")
    HTH
    Computer Specs:
  1. Specify the Plot Style for certain entities in a Named plot style drawing
    Last Post: 2014-10-28, 11:52 AM
  2. Change All Layers' Plot Style Setting
    By parker.depriest356295 in forum AutoLISP
    Last Post: 2013-02-05, 07:05 PM
  3. Named Plot Style OR Color Depemdent Plot Style
    By Masroor Javid in forum ACA General
    Last Post: 2007-09-11, 02:16 PM
  4. Setting Plot Style Table in Lisp
    By fletch97 in forum AutoLISP
    Last Post: 2007-01-30, 09:43 PM
  5. Setting plot window in plot preview
    Last Post: 2006-04-18, 07:51 PM
