Thread: Best practice for moving model/levels in projects
    2008-07
    Seattle, WA
    28
    Default Best practice for moving model/levels in projects
    So I enabled/created my work-sets, created my central, and local, not to mention link in the other disciplines. Everything came in perfect when I linked in origin to origin. I go to an elevation view and my levels are at 0'-0" and 10'-0" which I know are default from my project template. The architect is at a 100'-0". What is the best method/ practice for aligining my levels/grids. It is my assumption that it isnt as as simple as merely moving my levels (the host) to the elevation of the linked model (architect. mech) or vice versa. Was hoping to get the best practice for me (the host) to aquire the coordinates to the arch (linked model) as well as move the levels to the proper postion. I appreciate any help you can offer. Thanks in advance.
    2002-02
    St. Louis, MO
    4,695
    Default Re: Best practice for moving model/levels in projects
    Well it can be as simple as moving thelined model to align with yours. The position will remain and it can work just fine. We've done this when working with information coming from an outside consultant using tekla.
    A better approach would be for everyone to use the same Revit origin and elevations. Our template uses a couple of reference planes set at 0,0 to make that more visible to users. You can also go into your model and move your levels to match the architects 100' reference.
  1. Replies: 3
    Last Post: 2015-08-25, 05:23 AM
  2. 2012: Spot Levels - Best Practice
    By Bastiat in forum Revit Architecture - General
    Last Post: 2013-06-10, 02:54 PM
  3. Moving Levels AFTER most of model is created?
    By bwilliams133 in forum Revit Architecture - General
    Last Post: 2012-10-16, 04:54 PM
  4. 2012: Best practice for levels?
    By WolffG in forum Revit Architecture - General
    Last Post: 2011-08-10, 07:46 PM
  5. Autocad electrical 2008 tutorials or practice work projects
    By pankajganvit in forum AutoCAD Electrical - General
    Last Post: 2010-01-11, 02:42 PM
