Summary: I wish that I could pre-set the drawing units for each of my work space disciplines so that when I change work spaces the drawing units are already set for that Discipline.
Description: Hi, tired of setting your units each time you start a new session/drawing? I am and so is everyone else. Autodesk gave us the ability to creat and or modify work spaces. The only problem is they gave us something that is incomplete. At the last University I brought this up and was shrugged off so here goes. If I set up a work space I set it up by discipline. Architectural, mechanical, civil, it doesn't matter. Each uses a differant scale. So, I ask is why autodesk didn't give the option to set up the units in the work space setup?This way I could preset all my work spaces with the units, tools, menus etc... for that discipline.
See where i'm gong with this?
If I make an Architectural Work space I should be able to pre-set the units for that discipline so every time I use that work space it uses the correct units. Or if I want to create a new drawing using the mechanical work space it uses that disciplines units. This seems to be an idea that can kill the redundant task of setting up units each time you change disciplines
or create a new drawing.
Product & Feature: AutoCAD
Submitted: Fri, 17 Feb 2012
