Thread: How to fix a corrupt shapefile when using AutoCAD Map?
    2003-11
    442
    Default How to fix a corrupt shapefile when using AutoCAD Map?
    I was trying to edit polylines (waterlines) using AutoCAD Map 3D and after editing a few polylines some of the features I have edited are corrupt and do not show up when I add the shapefile to ArcMap.
    I am trying to edit waterline locations because we now have valve locations and the waterlines need to pass through the valves. When i had to edit a feature, I checked it out, added a vertex or split the polyline then checked it back in. What did I do wrong?
    What is the proper workflow so I don't hose my shapefile?
    Thanks.
    TN/KY Area
    1,640
    Default Re: How to fix a corrupt shapefile when using AutoCAD Map?
    Look for an .idx file in the folder with the shape file(s) delete it.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
  1. Does AutoCAD LT corrupt Fields
    By dfarris75 in forum AutoCAD Fields
    Last Post: 2007-05-24, 01:36 PM
  2. AutoCAD 2006 custom CUI's corrupt after loading AutoCAD 2008
    By jonathanschade in forum AutoCAD CUI Menus
    Last Post: 2007-05-24, 01:30 PM
  3. How do you enable automatic shapefile labling in AutoCAD?
    By sbruzda in forum AutoCAD Map 3D - General
    Last Post: 2006-03-07, 07:03 PM
  4. Corrupt AutoCAD dwgs
    By greg.hall81657 in forum ACA General
    Last Post: 2005-02-28, 01:58 PM
