Inukshuk
I have a multitude of lines starting from z=0 to z= varies. What i did was color each set of lines between the length of one unit,(1.2,1.7,1.96 etc) to a specific layer with a specific color. I did that with the quick select tool applied on the: entire drawing, object type: line, properties: length, operator: < less than, value : 10(9,8,7 etc), then move selected lines to a specific layer.
What i want to do is put this in a script, so far it should be something pointing in this direction.
ssx pick line length <20 layer blue
Obviously it would not work like that(syntax), but that is the main idea.
If it helps i have every coordinate in the drawing and i could try making them on separate layers from the start if possible, not just modify them afterwards.
