Thread: Troubleshooting A Corrupt Revit File
    2003-10
    15
    Default
    I updated a project recently and the new saved version will not open. Instead, I get the message, "An attempt was made to access (Project Name.rvt) past its end." The file does appear in the preview of the open dialogue menu. Also, the file size is unexplainably double of the previous saved version. Is this a Revit issue? System issue? Can the file be recovered?
    2003-05
    Northbrook, IL
    879
    Default Re: Troubleshooting A Corrupt Revit File
    I would call Revit support before trying anything else. They will probably ask you to email a copy to them. They can often fix corrupted files if they haven't been altered too much after the initial problem occured. Good luck.
    Robert Witte
    Autodesk Revit Client Support Manager slb's Avatar
    2003-07
    Waltham, MA
    107
    If you have an opportunity to go to a recent backup (perhaps in the previous version) please do.
    At the same time, please send us (RevitSupport@Autodesk.com) the corrupt file.
  1. .dwg file corrupt?
    By thibautcormier22682856 in forum AutoCAD General
    Last Post: 2014-12-01, 07:16 PM
  2. Corrupt File
    By comical_wenger in forum 3ds Max - General
    Last Post: 2010-10-06, 12:31 AM
  3. Corrupt file
    By Chris DiSunno in forum Revit Architecture - General
    Last Post: 2009-04-07, 04:19 PM
  4. Corrupt File
    By dsw98 in forum Revit Architecture - General
    Last Post: 2008-06-09, 04:50 PM
  5. Corrupt Revit File
    By Marv Muston in forum Revit Architecture - General
    Last Post: 2006-08-17, 11:29 PM
