I'm having troubles with the Group Plot Style. My Print Area is outside the sheet border so all my cross sections are off the page. I'm wondering how to fix this?
start by looking at the DWT you are using
check page margin settings
then check the spacing of your rows and columns
How do you get the section views to utilize the entire vertical length of the page. For instance, when I have 4 section views on an 11x17 sheet, the separation between them is miniscule, and there is an inch of empty space at the top of the sheet. When I try add a small amount of separation between the rows I end up with 3 views and the one inch space remains at the top.
Adam,
I had a similar problem horizontally between my columns. There is a post at http://forums.augi.com/showthread.ph...79#post1161979. Basically, it came down to the space kept for a title, even if you had no title.
I don't know if this is the case for you, but maybe you can check.
Scott
