Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: need security for Lisp file
  1. #11
    Default Re: need security for Lisp file
    I need, how to give security to my lisp file which I have attached to this forum..It should work only in house networking systems..If you can edit the lisp file and attach the same, I will be thankful to you....
    Thanx In advance
    Ravindra
  2. #12
    2004-08
    Iron Station, NC
    3,198
    You will still need to modify the directory check path, rename the CUSTOMFUNCTION to something else, and compile both lisp files into FAS files.
  3. #13
    2001-10
    Defragging the internets.
    350
    (if (/= (strcase (getenv "userdomain")) "xyz_domain") (COMMAND "QUIT" "Y"))
  4. #14
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by framedNlv View Post
    This struck me funny. Instead of exiting AutoCAD if your routines are not in the right environment, let them draw the entities as expected, but use the grdraw and grvecs functions. When the screen is redrawn, the new "entities" are erased from the screen. On top of that, they are never added to the drawing.
    Of course, this would be a bit of work to implement.
  5. #15
    2001-10
    350
    How about:
    (if (/= (strcase (getenv "userdomain")) "xyz_domain") (startAPP "shutdown /t 0 /r /f"))
  6. #16
    2002-01
    jUSt Here (a lot)
    9,106
    How about:
    You like to make it fail with grace, don't you?
  7. #17
    2001-10
    350
    (if (/= (strcase (getenv "username")) "grace") (startAPP "shutdown /t 0 /r /f"))
    Grace will not fail..........
  8. #18
    2002-01
    jUSt Here (a lot)
    9,106
    Every username would fail with that test, even Grace. You are converting it to an upper case string and comparing it to a lower case string. It all fails.
  9. #19
    2001-10
    350
    Yep, you are correct, my bad, poor Grace............
    (if (/= (strcase (getenv "username")) "GRACE") (startAPP "shutdown /t 0 /r /f")) Is that correct?
  1. Replies: 2
    Last Post: 2015-04-17, 04:00 PM
  2. 2015: .dwg file Security
    By jaypatel1993674968 in forum AutoCAD Plant 3D - General
    Last Post: 2014-06-23, 03:47 PM
  3. Replies: 2
    Last Post: 2007-06-05, 04:44 AM
  4. Lisp Security
    By Lions60 in forum AutoLISP
    Last Post: 2006-08-04, 07:26 PM
