Results 1 to 10 of 10
Thread: Open drawings in a single window/Abrir desenhos em uma única janela
    2012-03
    5
    Exclamation Open drawings in a single window/Abrir desenhos em uma única janela
    "Friends,
    Whenever I open a drawing in AutoCAD 2010, the design is loaded into a new AutoCad. I wish I had just opened with an AutoCad multiple windows. I tried setting in the Tools / Options but found the place to set ...
    Excuse the English description (I used the google translator).
    Thank you!"
    Amigos,
    Sempre que abro um desenho no AutoCad 2010, o desenho é carregado em um novo AutoCad. Gostaria que eu tivesse apenas um AutoCad aberto com várias janelas. Tentei configurar no menu Tools/Options mas não encontrei o local para configurar...
    obrigado!
    Cairo - no, not Illinois
    5,069
    Default Re: Open drawings in a single window/Abrir desenhos em uma única janela
    How are you opening the drawings? using Sheet Set manager (since that is where you posted), or double clicking in windows explorer, or using the File Open in AutoCAD?
    2012-03
    5
    Well, I open the archives with double clicking in windows explorer and using the File Open in AutoCAD. the problem occurs in the two cases
    Sorry for the post in the wrong place ....
    can you help me?
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    set SDI to 0.
    2012-03
    5
    I have not succeeded
    2005-02
    Off the Grid
    560
    Quote Originally Posted by deivish560900 View Post
    What do you mean? You were not able to change it to 0, or that didn't solved the problem?
    2012-03
    5
    that not solved the problem....
    2005-02
    Off the Grid
    560
    try TASKBAR set to 0.
    2012-03
    5
    Thumbs down Re: Open drawings in a single window/Abrir desenhos em uma única janela
    that not solved the problem to....
    very crazy...
    0,0,0 The Origin
    8,570
    This thread and links within it might help.
  1. Replies: 3
    Last Post: 2012-06-17, 09:42 PM
  2. Janela de abrir/salvar não abre - Autocad R14
    By msrmariana954734 in forum AutoCAD General
    Last Post: 2011-11-22, 05:29 PM
  3. Erro do Civil 3D na janela open
    By javahes in forum AutoCAD Civil 3D - General
    Last Post: 2010-08-21, 03:33 PM
  4. Abrir vários desenhos no mesmo autocad
    By ed_cristian.dwg in forum AutoCAD General
    Last Post: 2009-11-12, 02:39 AM
  5. Dockable window that shows open drawings
    Last Post: 2006-01-05, 05:56 PM
