Hi,
I am currently working on producing a flat compound with an access road tying into proposed main road. I have created main road corridor and the surface. So now I am moving on to the compound design. The main requirements for this compound are to be completely flat and to tie in to proposed main access road I created earlier. Also, the compound levels should get the cut/fill balance with the factor 1.3 cut to fill.
I am aware how to use the auto cut/fill balance tool however I don't know how to define the tie in levels to be set and not changed when the levels get adjusted to get the balance.
Also, I am not sure how to get the factor 1.3 cut to fill, however that could be another question. And I think I've seen the answer somewhere already.
I would appreciate a lot any of your help. I am running out of time
