Thread: Shared Parameters show up as question mark
    Active Member drafting1's Avatar
    Atlanta, Ga
    85
    Question Shared Parameters show up as question mark
    Hi All,
    I am new to Revit (2012) and have created a hanger family for conduit with shared parameters for rod length etc.
    When I load the family and shared parameters file into a project and try to add a tag with the shared parameters attached I get
    a question mark where my tag is supposed to be. I have messed with it for half a day and still no luck.
    Any suggestions would be appreciated.
    Mike
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    Default Re: Shared Parameters show up as question mark
    The presence of a question mark indicates that the label within the tag is not finding any parameter values to report. Ensure that the Family and the Tag both have the exact same Shared Parameter loaded into it - if one of them just has a Parameter named the same, you will get this result. It may be best to remove and replace the Shared Parameter in both families.
    100 Club RobG's Avatar
    2005-12
    Spokane, WA
    164
    This is an issue we're having with SOME families, but not all families. I don't recall older versions of Revit doing this. It has nothing to do with a shared parameter just being the same name, as we're having the issue with newly created shared parameters as well. Is there a setting somewhere that replaces the behaviour that blank cells for a tag are replaced with a Question Mark symbol?!?
    I remember last year having this issue with a tag family that was upgrade from 2009 to 2010 and all of a sudden adding a question mark while it didn't show it in 09. I can't remember which tag it was and i can't remember how we fixed it :/
    Any lead on this would be nice.
  1. Shared Parameters for Elevation Mark, Section Mark, Callout Head & View Reference Families.
    Last Post: 2021-04-21, 08:30 PM
  2. 2014: Criteria for Project Parameters vs. Shared Parameters
    By jagostinho in forum Revit - Platform
    Last Post: 2014-03-21, 02:46 PM
  3. 2013: section mark does not show on all levels.
    By Bluefairy in forum Revit Architecture - General
    Last Post: 2013-05-09, 03:44 PM
  4. Shared Parameters Question
    By dgreen.49364 in forum Revit Architecture - General
    Last Post: 2008-09-26, 04:51 PM
  5. Shared Parameters to show in Room Style Schedule
    By cstarr in forum Revit Architecture - General
    Last Post: 2006-05-27, 12:42 AM
