Thread: Scanned PDF XRef Not Appearing
    2012-02
    3
    Default Scanned PDF XRef Not Appearing
    Hi all, So I am having an unusual problem with my External References. I had to scan a document to use for XRef for a client project, and for some reason when I XRef the PDF into AutoCAD it just comes up with a blank empty square.
    Any Suggestions?
    Thanks
    2001-12
    St. Louis
    5,397
    Default Re: Scanned PDF XRef Not Appearing
    Does it only happen with that one particular file? or can you duplicate with other files?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2013-02
    I searched this today because I ran into the same problem. It is just the one file which I received from another company. I don't know what it is about this file that Map3D doesn't like but my solution was to open the PDF in Adobe Reader and "print" it to PDF, making a new copy with a clean history. When XREF'ed the new copy displays fine.
  1. 2013: Volume in Schedules appearing and not appearing
    By Chris.Partin in forum Revit Structure - General
    Last Post: 2013-02-20, 04:19 PM
  2. Scanned Image Format - Which Is Better
    By omorah in forum AutoCAD General
    Last Post: 2006-11-17, 07:47 PM
  3. Scanned Drawings
    By vq2 in forum ACA General
    Last Post: 2005-11-23, 05:54 PM
  4. How big are files when scanned?
    By GreyHippo in forum CAD Management - General
    Last Post: 2005-10-12, 07:07 AM
  5. Calibrate a scanned map in Architectural Desktop
    By peter_rose in forum Raster Design - General
    Last Post: 2004-11-08, 12:55 PM
Tags for this Thread
