Results 1 to 6 of 6
Thread: PLAN NOTES
    Member BRADLEY.BRIGMAN1819's Avatar
    2003-10
    Macon, Ga.
    12
    Default
    Is there some kind of trick to plan notes? I'm open for any tips on how others are doing plan notes!
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: PLAN NOTES
    Choices that I'm aware of are text notes (manually typed or text imported into them), generic annotation families (for stuff that repeats alot), convert catalog pdf's, word docs, or excell spreadsheets to bmp or jpg's & import them into your view / sheet. Do the text in autocad or microstation & import the dwg. Write the stuff on a sheet of paper, scan it as a bmp or jpg, & import it.
    Lot's of ways...
    2003-07
    Bethesda, MD
    92
    I usually just use text notes...and if they repeat just copy and paste it... if they repeat in multiple projects a generic annotation would work just as well...if they repeat in every project, then maybe use a template file with the notes in it...
    All AUGI, all the time Allen Lacy's Avatar
    2003-04
    Richmond, VA
    545
    Also, if your notes repeat you can group them. Then if you make a change to one instance (edit group), all the others will be updated automatically.
    2003-10
    Macon, Ga.
    12
    Thanks for the tips! I used text and groups and it works fine!
    All AUGI, all the time Henry D's Avatar
    2003-05
    Fairfield, Iowa
    669
    AJ Holland posted a nice way of doing key notes see this thread: GO THERE
  1. General Notes/ Plan Notes/ Sheet Notes
    By ubviswa in forum Revit Structure - General
    Last Post: 2012-12-04, 05:32 PM
  2. Plan Notes
    By Nun_Ya_Bez in forum Revit Structure - General
    Last Post: 2009-06-27, 10:54 PM
  3. Creating plan notes.
    By Shaylon Vaughn in forum Revit Structure - General
    Last Post: 2009-06-23, 05:10 PM
  4. Specific Demo Notes, Plan Notes etc.,
    By tmcguire17 in forum Revit Architecture - General
    Last Post: 2009-03-13, 06:17 PM
  5. Is anyone doing Plan Notes?
    By clintr in forum Revit Architecture - General
    Last Post: 2006-06-29, 06:16 PM
