I have seen links on this before, but I still cannot figure out where my stuff is. I am trying to run a pipe network and get this error when I go to set my first structure. How do i fix it. I am using Civil 3D 2011 and Windows 7.
In the VBAIDE command which loads Microsoft Visual Basic under tools, references, it says Im "MIssing: AEC Base 6.5 Object Library".
Under c:\Program FIles\Common Files\Autodesk SHared\AecXBase65
I cannot find this file. Where can I get it?
The file is there, but it still says its missing.
Have you attempted to use APPLOAD and load it prior to creating your pipe network(s)?
Are these custom pipes, or parts?
And is the catalog pathed correctly?
