Thread: Dimensioning to Cable Trays Cut by View
    2004-10
    Appleton, WI
    55
    Default Dimensioning to Cable Trays Cut by View
    I would like to add some dimensions to cable trays in both plan views and section views. It seems like I am only allowed to dimension to the center of a cable tray and cannot dimension to the edges. Has anyone else run across this problem or found a solution?
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    Default Re: Dimensioning to Cable Trays Cut by View
    Set the Detail Level to Fine and turn off the Cable Trays subcategories "Drop" and "Rise".
    2011-04
    That did not work, perhaps there is a dimension setting I am missing.
    2012-01
    813
    Here's what mine looks like:
    I'm able to dimension from any face of the Cable Tray. Does yours appear differently?
    2011-04
    You are right! It is working now...Hmmm but I've tweaked so many things in the past hour I'm not sure which worked Ahhhh. using Aligned works but Linear seems to lock on the center-line...Thanks.
  1. Replies: 1
    Last Post: 2017-11-01, 03:46 PM
  2. Electrical - Cable Trays - My 1st Contribution
    By pierredib in forum Dynamic Blocks - Sharing
    Last Post: 2017-03-12, 11:53 AM
  3. parameter for cost of cable trays
    By dirka529229 in forum Revit MEP - General
    Last Post: 2014-08-14, 01:45 PM
  4. Cable Trays...
    By rtgis in forum Revit MEP - Families
    Last Post: 2009-09-27, 10:07 PM
  5. 3d Cable Trays
    By prashant.gholap in forum ACA General
    Last Post: 2009-07-29, 04:35 PM
