Thread: Map VBA's VLAX ?
    100 Club KevinBarnett's Avatar
    2001-10
    Pretoria, South Africa
    119
    Question Map VBA's VLAX ?
    Greetings,
    I am trying to issue ade functions within VBA (Map 2005) using Frank's VLAX:
    retval = obj.EvalLispExpression("(ade_projsetsrc " & _
    Chr(34) & ComboBox1.value & Chr(34) & ")")
    retval = obj.EvalLispExpression("(ade_projsetdest " & _
    Chr(34) & ComboBox2.value & Chr(34) & ")")
    retval = obj.EvalLispExpression("(ade_projptforward " & _
    "(list " & Trim(TextBox1.Text) & " " & Trim(TextBox2.Text) & "))")
    But it does not appear to respond.
    I have a feeling that this line in the class:
    Set VL = ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
    is only loading the base lisp and not the ade's.
    Does anybody know the solution?
    Kevin.
    Acad 2007, Autodesk Map 3D 2007, 3D, VBA, Lisp, C#.Net, Windows XP Pro (been using AutoCAD since 1989)
    Turlock, CA
    5,867
    Default Re: Map VBA's VLAX ?
    ade is not lisp. they are commands loaded from an arx. Try the (command) function, since you are using vlax. Otherwise use SendCommand.
    C:> ED WORKING....
    2001-10
    119
    Thanks. The follwoing worked, but could I have completed the task in less steps?
    Sub try()
    ThisDrawing.SendCommand "(ade_projsetsrc " & _
    Chr(34) & "Lo-27-WGS" & Chr(34) & ")" & vbCr
    ThisDrawing.SendCommand "(ade_projsetdest " & _
    Chr(34) & "LL" & Chr(34) & ")" & vbCr
    ThisDrawing.SendCommand "(setq a (ade_projptforward " & _
    "(list 99229.367 2820428.461)))" & vbCr
    ThisDrawing.SendCommand "(setvar " & Chr(34) & "userr1" & Chr(34) & _
    " (car a))" & vbCr
    ThisDrawing.SendCommand "(setvar " & Chr(34) & "userr2" & Chr(34) & _
    " (cadr a))" & vbCr
    Dim X, Y As Double
    X = ThisDrawing.GetVariable("userr1")
    Y = ThisDrawing.GetVariable("userr2")
    MsgBox CStr(X) & "," & CStr(Y)
    End Sub
  1. vlax-put-property
    By jkleinowski in forum AutoLISP
    Last Post: 2011-01-21, 04:47 AM
  2. vlax-curve and UCS
    By irneb in forum AutoLISP
    Last Post: 2010-01-25, 01:02 PM
  3. Map VBA's VLAX ?
    By KevinBarnett in forum AutoCAD Map 3D - General
    Last Post: 2005-01-27, 09:00 AM
  4. vlax-invoke
    By mahazen in forum AutoLISP
    Last Post: 2004-08-07, 04:05 PM
