Thread: Lighting problem: TOO much Light, Render 3dmax vray.
    2010-06
    Monterrey
    9
    Lightbulb Lighting problem: TOO much Light, Render 3dmax vray.
    Hello,
    I'm using 3dmax 8 and vray to make this render.
    The Vray GI Environment is checked with 1.1 and I have a Direct Light with 0.55 (vray shadows on)
    You can see exactly what the problem is in the pictures, why is there too much light there and how can I fix it???
    I've tried with photoshop to do it manually but it's taking me too long.
    I hope you can help me.
    2007-08
    Denver, CO
    334
    Default Re: Lighting problem: TOO much Light, Render 3dmax vray.
    Looks like a GI bounce issue (light splash). Are you using VRay Physical cameras? If so, just dial in the F-stop. Also, make sure caustics are turned off.
    If using standard cameras, try setting some exposure controls in the Environment panel. It's been several years since I've done that but I recall some tweaking.
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    I'd suggest following what Glen's advised, but I'd also keep in mind that it can only go so far - although they're two different walls, they're also colored the same with very similar lighting; even in a real-world situation, they wouldn't have a lot of contrast between one wall and the other. You can raise your f-stop, but that's going to darken the shadowy areas in the entry/carport areas. If you want that definition, you may have to fake it by raising your f-stop and adding a light or two in the darker areas. Just some food for thought.
  1. 2013: Lighting Fixture Light Source Shows Black After Render in Cloud
    By BIMbeliever in forum Revit MEP - General
    Last Post: 2013-04-12, 01:05 PM
  2. Demasiada luz en las uniones. Render/3dmax/Vray
    By misskeki in forum 3ds Max - General
    Last Post: 2012-04-23, 02:57 PM
  3. Petit film 3Dmax/Vray by Alex Roman
    By METANAMORPHOSE in forum 3ds Max - General
    Last Post: 2011-02-09, 08:08 PM
  4. Render lighting from Light in XREFS
    Last Post: 2009-08-25, 12:07 PM
  5. Autocad 2009 Render / Lighting Problem
    By tlitke in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-12-25, 09:46 AM
