Thread: Revision Cloud
    2012-04
    Default Revision Cloud
    This question may have already been asked somewhere in this forum. Is there a way to draw a revision cloud without having to continuously draw the two arcs and keep connecting? AutoCAD is set up to either hold click and drag or convert polygon to cloud which requires significantly less time. Please advise if anyone knows.
    2015-11
    Madison, WI
    1,317
    Default Re: Revision Cloud
    No, This has been a complaint/wishlist for a while.
    Sorry,
    Jeff
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    This doesn't really address your question, but here's something I just discovered last week:
    Did you know you can use the Split tool on a Revision Cloud?
    If, after you've drawn your Cloud, you don't like where the arcs are, or if the Arcs are too big, you can use the Split tool to break a large Arc into two smaller ones.
    2003-03
    Philadelphia, PA
    2,390
    Great tip! You do have to be in sketch mode for the revision cloud, but the Split tool does work.
  1. Revision Cloud
    By rhayes.99001 in forum ACA General
    Last Post: 2010-06-21, 04:56 PM
  2. Revision Cloud
    By johnthao714 in forum Revit Structure - General
    Last Post: 2010-04-09, 08:17 PM
  3. Revision Cloud and Tag
    By techsupport.161645 in forum Revit Architecture - General
    Last Post: 2010-03-19, 11:41 AM
  4. Revision cloud properties in cloud sketch
    Last Post: 2009-02-01, 07:08 PM
  5. Revision Cloud
    By ljones.27809 in forum AutoCAD General
    Last Post: 2005-09-01, 06:35 PM
