Thread: FORMATING ON SHEETS
    2011-07
    9
    Default FORMATING ON SHEETS
    Can conditional formatting be set to allow transfer from the view to the sheet?
    I have set up a conditional format to show the difference between a programmed area and an designed area. If the difference is greater than 5% the cell shows up in red on the view. When the view is posted to the sheet, the conditional format in "red" does not show up on the sheet.
    It would be helpful when sending the sheet to someone for review that the highlighted cells of the schedule show up on the sheet. As I don't think it is not possible to print a schedule view, the highlighted cells are only visible within the program and can't be shared.
    Anythoughts?
    Glen
    Orlando, FL
    1,049
    Default Re: FORMATING ON SHEETS
    No. This is still in the wishlist.
    2015-11
    Madison, WI
    1,318
    Glen,
    Try filtering your schedule by your calculated value. Drag this to a 8.5x11 sheet and print that. I would like to see calculated values available in a room's properties.
    Thanks,
    Jeff S.
  1. Conditional formating in schedules
    Last Post: 2012-07-24, 03:34 AM
  2. remove formating of dim
    By clovis in forum AutoLISP
    Last Post: 2011-05-04, 02:47 PM
  3. formating text strings
    By rwbaker in forum VBA/COM Interop
    Last Post: 2005-09-20, 06:02 PM
  4. ASCII Formating
    By tommy.huckabee in forum AutoCAD Wish List
    Last Post: 2005-04-05, 12:29 PM
  5. Schedule Formating
    By David Sammons in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-12-20, 03:08 PM
