Job Preferences->Databases->Steel and timber sections->Add->Declaring Section Database->Browse->Open
After clicking OK, I get the following error:
Try to run RSA as Administrator (right mouse button on RSA icon and "run as administrator" option).
Probably copying manually r_norm.cfg file from path above into cfgusr directory (on W7 examplary path is C:\Users\user_name\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\CfgUsr\) would help.
Running as administrator helped. Thank you.
