Thread: Double Coding Line work
    2012-02
    3
    Default Double Coding Line work
    I am trying to double code line work. I brought in a .csv file and I had a few double codes that did not connect. My code was EOG2 ST ENT, for Edge of Gravel, also starting an entrance. The line work will not connect from my previous Edge of Gravel shot to this one. Any reason why?
    2015-12
    Arizona
    2,478
    Default Re: Double Coding Line work
    do you have auto start on figure prefix matching enabled?
    have you tried adding a B code after the ENT?
    2013-10
    2
    I'm not sure how to deal with this either. My survey is simpler but I still don't know what to do with this since you really can't have a point in two point groups. and display differently. For example I have EP for Edge of Pavement and EPIN for Edge of Pavement and and Inlet in the curb. I would appreciate some advice.
  1. MEP 2011 - Problem with Hidden line view in double line piping
    By cdonahue278905 in forum Revit MEP - General
    Last Post: 2011-04-01, 06:18 AM
  2. Pipe Single line and double Line
    By Gindelicato in forum Revit MEP - General
    Last Post: 2009-10-17, 02:06 AM
  3. Specify double-line or single-line ductwork?
    By seventwo in forum AMEP General
    Last Post: 2008-12-18, 08:27 PM
  4. Set up a Hyperlink in a DWG to work with a double-click
    By clive.shipping in forum AutoCAD General
    Last Post: 2006-11-22, 04:10 PM
Tags for this Thread
