Hi, when I select some polygons and try to use -mapexport from the command line manually and programmatically it gives me "0 object(s) of 0 selected, exported in 0 sec(s).".
This is what I try to run programmatically (and the same thing from the command line)
docum.SendCommand("-mapexport" + vbCr + "shp" + vbCr + inFile + vbCr)
If isOverW Then
docum.SendCommand("O" + vbCr)
End If
docum.SendCommand("Y" + vbCr + "X:\Legends\Test.epf"+ ".epf" + vbCr + "S" + vbCr)
docum.SendCommand("P" + vbCr + "M" + vbCr + "last" + vbCr + vbCr + "*" + vbCr + "*" + vbCr + "N" + vbCr)
docum.SendCommand("P" + vbCr)
It is not an issue with my profile because I can use it with Map->Tools->Export->Shape. It seems like when I try to run the command the selections are lost and I'm not sure why.
I also get a problem when I try to select polygons and then go to Map->Tools->Export->Shape where they are lost there as well. However, if I select them again, import the same profile I am trying to use above and run it, it exports to a shape file correctly.
I have AutoCAD Map3D 2011 set to allow selections before command and it works for other commands
Any help would be appreciated, thanks.
