Thread: Can't stylize polygon??
    2012-03
    Default Can't stylize polygon??
    Forgive me, I'm new to AutoCAD Map. I have connected to a shapefile, and am trying to stylize it via the Display Manager. I can change the only the colour, but changing the thickness or line style has absolutely no effect, either in the drawing or when plotting to pdf. What am I doing wrong? I open the Style dialog, click the ellipsis beside "Style", and change the line thickness next to the "Line Color" drop-down, and the preview polygon completely fills in if I use anything other than 0. But in the drawing after I apply and close, nothing happens. If I try and change the line style, the preview changes, but again nothing changes in the actual drawing. I'm using 2012.
    2012-03
    Default Re: Can't stylize polygon??
    Well I tried it in 2010 and it works fine...suggesting there's a bug in 2012.
    2001-07
    8
    It works fine with me in 2012
  1. Polygon Scope Box
    By Beginner Revit User in forum Revit MEP - General
    Last Post: 2015-01-15, 09:06 PM
  2. GS314-1L: Stylize It: The AutoCAD Map 3D Display Manager
    By Autodesk University in forum Planning and GIS
    Last Post: 2014-12-01, 03:35 AM
  3. Replies: 0
    Last Post: 2014-12-01, 03:28 AM
  4. Stretch a Polygon/Maintain the Original Area of Polygon
    Last Post: 2007-08-02, 04:39 PM
