Results 1 to 9 of 9
Thread: Dimension between angled points
    Revit Mararishi aaronrumple's Avatar
    2002-02
    St. Louis, MO
    4,695
    Default Dimension between angled points
    Problem: You want to dimension between two corners at some odd angle.
    Just place a refernce line prependicular to the direction of your dimension. Start your dimension at the ref. plane. The dimension the points. Now delete the ref. plane. The dimension stays aligned... (see attached.)
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    Default Re: Dimension between angled points
    That is a terrific tip. Dimensioning to odd angled property lines is now a snap. I would have thought the dimension would disappear when you delete the reference line but it does not. Thanks!
    Joe
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    wow, that's a fabulous tip! I like it.
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    405
    Question Re: Dimension between angled points
    Quote Originally Posted by aaronrumple
    Aaron,
    I posted something similar the other day in response to a query on dimensioning angled walls....I noticed though that you say to delete the reference planes...I tried to do that and the dimensions delete with them...I wasn't worried too much because the ref planes don't print but I would like to know how to get rid of these planes if necessary....Is there a lock that I'm missing?
    John Mc
    2002-02
    St. Louis, MO
    4,695
    The ref. plane is used to get started only. The other witness lines are on points - not ref. planes. These witness lines remain when the ref. plane is deleted.
    2004-05
    Brisbane, Australia
    405
    ...Ah!...ta, Aaron
    John Mc
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    And that is why you are the "guru" Aaron!
    Steve
    2019-05
    How do you dimension from corner of a furniture (let say, a bed or dresser) to a angled wall? Thanks for the input
    2010-10
    Chicago, IL
    376
    Activate dim command, pick a wall first and then hover over the furniture corner - dim will snap to the corner point. If not, use a tab key.
  1. Angled Dimension
    By hellera236231 in forum Revit Architecture - General
    Last Post: 2012-03-08, 04:50 PM
  2. Dimension to angled wall
    By waghorne in forum Revit Architecture - General
    Last Post: 2008-01-30, 04:10 PM
  3. dimension issue with curved and angled walls
    By jarod.tulanowski in forum Revit Architecture - General
    Last Post: 2005-06-23, 06:16 PM
  4. Dimension to Core Face of Angled Wall Joins
    By Mike.68517 in forum Revit Architecture - Wish List
    Last Post: 2004-06-25, 03:38 AM
  5. Dimensioning points on angled walls
    By christo4robin in forum Revit Architecture - General
    Last Post: 2004-04-27, 08:04 PM
