Thread: Help w/ Part - why cant I try a spline/ Curve?
    262
    Default Help w/ Part - why cant I try a spline/ Curve?
    Guys, with a lot of efforts and lots of reading here I was able to mode a part:
    I made a rectangle and swept some profiles along to create some grooves, the profile I drawn in red.
    I want to remove the portion that is in pink from the point to the red line #1, so that I am left with an outline represented by the blue line.
    I have started a new sketch and projected the yellow curves from the model and drawn in a line like #1. however I am unable to trim the yellow curves EVEN after I disassociate them from the part they are projected from.
    I am thinking that I want to create a shape like #2 drawn in black and for an extrusion to cut out what I do not want. However I m not successful.
    However while the 2 distance chamber was able to give me close results, it is not what I want. I need the resulting edge to be parallel to the holes a specific distance.
    Any ideas?
    Williamsport, PA
    641
    Default Re: Help w/ Part - why cant I try a spline/ Curve?
    Attach your ipt file here.
    262
    Here you go, thank you.
    PART TEST.zip
  1. Replies: 0
    Last Post: 2013-05-06, 01:33 AM
  2. Replies: 0
    Last Post: 2013-05-06, 01:28 AM
  3. MA11-5: Autodesk Inventor® Part Modeling: The First Step [Part 1]
    By Autodesk University in forum Manufacturing
    Last Post: 2013-04-17, 04:54 AM
  4. Drag or paste part into another part file to create assembly
    By Wish List System in forum Inventor Wish List
    Last Post: 2012-09-13, 07:08 PM
  5. Replies: 0
    Last Post: 2011-10-04, 11:16 PM
